NI TestStand
Teststand fails to use app with custom user settings
For a teststand project, I have to use an .Net application that is using a custom settings provider. The problem with it is that each time it is trying to use one of the user setting from teststand, the application returns an exception:
"Failed to load provider type".
I tried to illustrate with the small demo project that I attached.
The .Net application I call from test stand is AppWithUserSetting, and one of the step in the sequence File q.seq is to get a value of a user setting. That's where it crashes for me.
On the other hand, if I instantiate the same objects and read the same user setting from another .Net application (DoLikeTestStandApp), everything is fine.
Note that in the settings.designer.cs file of AppWithUserSetting, a custom line was added ([global::System.Configuration.SettingsProvider(typeof(AppWithUserSettings.UserAppSettingsProvider))] ) to force the program to use the custom SettingProvider. And that's where it fails when loading from teststand.
Any idea why? At this time, I would rather not remove the usage of that  custom settingProvider since it allows to keep user settings even when upgrading to different version of AppWithUserSettings.
Thanks and regards,
Loic
PS: I am using VS studio 2008 SP1 and Teststand 4.1.1
(4,377 Views)
Dear Loic.
Thank you so much for your post on our webforum and the great example. I noticed the problem and a few day back I forwarded this to my colleagues in the US. This is not the behaviour we suspected so the issue will be reviewed by our R&D team. I will inform you when I have any more news.
Martijn S
NI Netherlands
(4,318 Views)
Martijn,
Thanks for looking into the issue.
Loic
(4,313 Views)
I believe you are running into the same problem as this poster:
http://forums.ni.com/ni/board/message?board.id=330&thread.id=27317&view=by_date_ascending&page=1
Please read the posts and see if any of this information is helpful in solving your problem.
-Doug
(4,290 Views)
Accepted by topic author chouch
Loic -
As Doug mentioned, you are indeed running into an issue similar to the one in the other forum thread he pointed to. I have gone ahead and implemented the workaround solution for this issue in your provided example and attached it below.
Hope this helps. Let me know if you have any questions.
Manooch H.
(4,263 Views)
Loic -
I forgot to mention that if you implement this solution after already receiving the error, and you receive the error again, please try closing TestStand and re-starting it.
Manooch H.
(4,261 Views)
Manooch,
Great! Thanks for the workaround it works perfectly.
Loic
(4,188 Views)
