NI TestStand
Teststand deployment error without error number and listing out error module
I have been getting an error message mentioned below,
While Processing VIs...
Error: Unable to find all subVIs from saved VIs. Either a subVI is missing or the VI is not saved in the current LabVIEW version.
Please consult TestStand online help to get more information on how to resolve deployment errors.
Can anyone help me out to fix this this ?
Things tried so far;
  1. Opening all the top level VIs, subVIs and save all
  2. Mass compiling of instrument driver folder and other almost all the fielders
More info:
LabVIEW version: LabVIEW 10.0.1
TestStand Version: TestStand 2010 SP1
Thank you
Adarsh
Adarsh
CLA - Certified LabVIEW
Architect
https://www.youracclaim.com/badges/4871da75-1b8b-422a-a881-9ab206d2d36d/public_url
(3,220 Views)
try running up the seqeditor with the labview adapter set to the RTE and then load your sequence files  to see if this helps with identifying which VIs are having problems.
Also dont forget to mass compile the TestStand area as these have VI's that might be called up in your Code modules.
Regards
Ray Farmer
(3,214 Views)
See here for more steps on how to troubleshoot this.
CTA, CLA, MTFBWY
(3,208 Views)
