03-20-2008 01:48 PM
03-27-2008 10:23 AM
As you could see in the following KB: How Can I Edit and Save Changes for the Current User? you have to get the users file as a PropertyObjectFile as it's done in the CreateDeleteUsers sequence, and then use two methods, IncChangeCount() wich is also already done in the example sequence, and the SaveFileIfModified().
See attached file below for the example sequence changed with the file saving.
Olivier L. | Certified LabVIEW Developer
03-27-2008 01:09 PM
