NI TestStand
Teststand-Engine and Delphi5 ?
Does Anybody use the TestStand-Engine with Delphi5 ? I started to look at
it, but didn't find out how to use some of the engine's methods and
properties.
Martin H. Kellner
(5,372 Views)
Martin,
Currently, we don't have an Delphi examples, but we will work on a simple
example.
Put the TestStand ActiveX control on your Delphi panel. This will instantiate
the engine. This control will also act as the UIMessage Handler. You can
also refer to the simple operator interface examples in the TestStand\examples
directory.
Paul Mueller
NI
"Martin H. Kellner" wrote:
>Does Anybody use the TestStand-Engine with Delphi5 ? I started to look at>it,
but didn't find out how to use some of the engine's methods and>properties.>>Thanks>>Martin
H. Kellner>>>>
(5,372 Views)
Thanks Paul,
I got TestStand working in Delphi5:
- Calling a SEQ-File with VIs as teststeps. I didn't improve it until
now, because I couldn't read the whole ActiveX-document of the
TestStand-Engine. But it works very very basically.
Martin
Paul Mueller schrieb:
> Martin,
> example.
> directory.
> Paul Mueller
> NI
to look at>it,
> H. Kellner>>>>
(5,372 Views)
