NI TestStand
Teststand 2017 ASAM XIL Value Factory unable to locate file.
While creating an ASAM XIL object reference for initialization of ETAS EE. I am getting an error in Teststand 2017 x64, whereas I have run this step previously while it was running smoothly but after unloading all modules, I am getting this error even after killing the processes and restarting the restarting the machine I am unable to execute this step and unable to create object reference. Just wanted to know if there is any issue with .Net or file access permissions.
An exception occurred inside the call to .NET member 'ValueFactory':
System.IO.FileNotFoundException: Could not load file or assembly 'ASAM.XIL.Implementation.Testbench, Version=2.0.1.0, Culture=neutral, PublicKeyToken=a258c402a414cddb' or one of its dependencies. The system cannot find the file specified.
File name: 'ASAM.XIL.Implementation.Testbench, Version=2.0.1.0, Culture=neutral, PublicKeyToken=a258c402a414cddb'
at ETAS.EE.XIL.API.Testbench.LabCarTestbench.get_ValueFactory()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
it seems from the error it is not able to locate the testbench files whereas the testbench files are located in the same folder.
Message 1 of 1
(884 Views)
