NI TestStand
Teststad/Labview installer
I have created user interface to call test stand sequences using labview(Modified pre shipped one).I created application installer using labview application builder utility.
But i was not sure how include test sequences created in teststand and related code modules in the installer.And how to deplopy new sequences created into this application.
Is this the correct approach to use labview application builder or should be using teststand builder?
Thanks and Regards,
Chethan
(2,872 Views)
To deploy sequence (and thus all the code modules), you need to use TestStand Deployment Utility. You can check this tutorial, of how to create deployment.
(2,850 Views)
