NI TestStand
TestStand v3.0 for multiple test sequence runs
I am trying to setup the TestStandv3.0 so that it can execute multiple
test sequences. Currently it executes one sequence and then rather
than reporting the test results in an HTML format, it terminates and
the entire tool quits execution. How do I fix this? I did not get
this problem with TestStand v1.0.1 of of the box.
(2,764 Views)
It maybe that in the Station Options under the Execution Tab, for the
On Run-Time Error control.
Make sure the 'Immediately Goto Cleanup on Sequence Failure' is not
checked.
Regards
Ray Farmer
(2,764 Views)
