John -
The error -2147221164 (80040154)is a COM error which is described as "Class not registered." This makes me think that ADO did not get installed properly.
Try the following. Create an empty text file and name it "Test.udl". Double click on it to see if you get a Data Link Properties dialog box.
If the dialog does not appear than ADO might not be installed properly.
If the dialog box does appear, attempt to fill out the dialog as the documentation suggests and then use the Test Connection button on the second tab to see if you can connect to the new database that you created.
You may want to reinstall ADO. The ADO 2.0 version that TestStand normally installs in copied to the following directory:
\Setup\Engine\MDAC\. Ru
n "setup.exe".
You can also download the latest version of ADO from microsoft's web site. The think the latest is 2.6
Scott Richardson (NI)
Scott Richardson
https://testeract.com
