NI TestStand
TestStand open problem
I'm working with TestStand 2010.
Today I opened TS and saw strange window on the top of TS:
This window hides the menu, the edit window and does not allow proper work. I did not find any way to remove it. Even TS repair did not solve this problem.
If I open a sequence, a part of a file is hiding behind this window.
Does anybody know what is that and how solve the problem?
(3,691 Views)
Accepted by topic author Berezka
Try resetting the UI to the default configuration:  With the sequence editor selected, hit 'ALT+V' and then 'R'.
I tried to reproduce the screenshot by changing the monitor resolution with the floating 'Step Settings' and 'Output' windows floating near the top of the screen but I couldn't put it in a state that the picture showed.  Do you remember how the editor got in that state?
Jim
(3,683 Views)
Hi Jim,
Thanks! It worked!
I already uninstalled TS and installed it again - did not help.
I don't know how the editor got in that state. When I closed TS last time (before that window appeared) everything was fine.
Berezka
(3,682 Views)
