NI TestStand
TestStand Sequence File XML (most readable, largest) File Format
I'm looking for some documentation around the xml file format for a sequence file.
In the file itself in the <teststandfileheader> element, the "xmlns" attribute points to "http://www.ni.com/TestStand/22.0.0/SequenceFile" however this leads nowhere.
does anyone now where i might found this information?
(1,376 Views)
The URL is used as a namespace is not a valid URL.
You can find the schema for the XML file at <ProgramFiles>National Instruments\TestStand>\Components\Schemas\Files.
Anand Jain
NI
(1,345 Views)
Thank you that's a great help.
(1,331 Views)
