NI TestStand
TestStand Error
I get the following error when starting TestStand. Any suggestions on how to clear it, other than reload TestStand? I tried opening SequentialModel.Seq in the sequence editor and resaving it.
Cannot load the sequence file's model entry points.
Type 'TElnf' is invalid because it conflicts with the existing type of that name. To avoid this error message, you should open the file
with the type conflict in the Sequence Editor and resave it.
Error accessing item 'Action.TS'.
The sequence file 'C:\TestStand\Components\NI\Models\TestStandModels\SequentialModel.Seq' could not be loaded.
Error Code: -17329, Invalid type - conflicts with an existing type.
Source: 'TSAPI'
(3,261 Views)
Nemo anwers this query which looks too be related.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000091410000&ECategory=TestStand
Regards
Ray Farmer
Regards
Ray Farmer
(3,261 Views)
