NI TestStand
TestStand API multithread UI example
Hi ALL,
is there any example for multi-thread and multi-window application based on TS API, it could be CVI or .NET.
I'm looking for something like that when 4 pcs of sequence view are running parallel and independently.
I managed to prepare an application with single sequence view, exchange values between the UI and TS or handling callbacks.
Then I tried to put the whole thing in a thread and start it multiple times but I got an error message which described that the application mgr can be loaded ones, or there can be only one instance.
Can anybody help with an example ?
br Adam
Message 1 of 1
(1,061 Views)
