NI TestStand
TestStand 2014
I need to call a VI develop to use NI 6001 DAQ module. The VI was developed in Labview 2015. I compiled it in LV 2014. I installed latest DAQMx, 2014RTE, 2014RTE SP1 on target computer. When i try to call the VI, Teststand tries to search for some other VI's in Teststand's sub folders?
Can anyone tell me some rule of thumbs to call VI's from Teststand?
Message 1 of 12
(4,714 Views)
Hi hedehodo,
I recommend checking the following links for best practices with importing LabVIEW code modules:
Best Practices for Code Module Development
On the LabVIEW Adapter
Message 2 of 12
(4,679 Views)
Thanx for prompt reply but these general informations actually don't help. I already passed through  them and couldn't figure out the solution. Somehow Teststand doesn't recognise the VI but why?
Message 3 of 12
(4,660 Views)
What TestStand system have you got deployed on the target system, is it the full version or a runtime version?
What errors or being displayed?
Regards
Ray
Message 4 of 12
(4,657 Views)
Hi Mr. Farmer,
We're working on Teststand 2014 development at the moment and we'll deploy deployment licence if we can overcome this issue. I provided some screenshots at my previous mail. The problems occurs if we use our dll for RS232 communication as far as i debugged. But in general .net dll's are problematic
Message 5 of 12
(4,653 Views)
Hi hedehodo,
I'm not sure what you mean when you refer to screenshots in a "previous mail", but if your program is having trouble locating a .NET dll I'd make sure you're following the guidelines in this article
Message 6 of 12
(4,643 Views)
Maybe this article
might help
Just a note, it not wise to have two threads running reporting the same problems;
previously reported problem
regards
Ray
Message 7 of 12
(4,632 Views)
Hi Ray,
That article is about how Labview handles .net calls but we don't have any Labview component in our Teststand flow. But if you mean anything behind the scene maybe that may help.
Actually i am trying to understand how is Teststand handling .net
Message 8 of 12
(4,627 Views)
ok now I am confused.
[I need to call a VI develop to use NI 6001 DAQ module. The VI was developed in Labview 2015. I compiled it in LV 2014. I installed latest DAQMx, 2014RTE, 2014RTE SP1 on target computer. When i try to call the VI, Teststand tries to search for some other VI's in Teststand's sub folders?
Can anyone tell me some rule of thumbs to call VI's from Teststand?]
Above was your original question?
So the problem is???
regards
Ray
Message 9 of 12
(4,624 Views)
Hi Ray,
As per the article you sent has a .net content i thouht you're replying one of my other subject about .net dll crashes which is still open
Actually the VI calling issue isn't also solved yet, but i compiled it as a dll and now it works.
Message 10 of 12
(4,621 Views)
