NI TestStand
TestStand 2010 Test Sequence Does not Work on Window7 System, Error code -17502
I have very short test sequence calling function from C++ DLL. The sequence works well on windows XP system, but when I run it on windows 7 system, I got Error Code 17502. I use teststand 2010. The function is initialize a communication between PC on my UTS system and the UUT board.
Thanks ahead for answering my question.
(3,451 Views)
The problem is probably due to your code module DLL not being compatible with windows 7 rather than TestStand.
You may need to upgrade any drivers you have for your UTS system.
Regards
Ray Farmer
(3,450 Views)
I re-compiled the DLL on windows 7, it's still not working. I am wondering what driver I need to upgrade on my UTS.
Thank you very much for your reply. I just get back to this project.
Sunny
(3,384 Views)
Hey Sunny,
The drivers you may need to update will be very specific to your application and what drivers it requires. Are both your systems 32-bit systems?
What are details of your error message?
Luke W
(3,350 Views)
