NI TestStand
Test execution error
Hi all
I make my own Operator Interface on the base of test Stand OI.
I am not sure , that it is a reason of my problem, but sometimes (one time in several days), duaring testing popup message.
Please find it attached.
Please, look it and help me, because I have no idea where I can start investigation
Thanks a lot Valery
(3,750 Views)
Hi Valery,
Unfortunately it is not every helpful.
It looks like something serious has happened causing TestExec.exe to close.
Do you know what step or code was running at the time.
Are you able to run the test sequence using the default Testexec.exe to see if its the UI or the code in the Test Sequence file?
Regards
Ray Farmer
Regards
Ray Farmer
(3,745 Views)
Hi Valery,
Are you still having problems or have you found a solution? If you would like anymore help with this issue, please let me know!
(3,674 Views)
Hi Corbin H.
 Yes, I still have this error ((( And I need help
Unfortunately, station with this code runs in Philippines and I have not possibility to investigate the problem in details.  I think that the problem is related to batch loop, that is in batch model (I am using batch model for client sequence). I have made some changes in this code too.
Please find attached my “batchmodeluutdlg.c” file and “TestExec.prj” (it is a project of GUI).
May be you will need "db" folder (attached too) , set it in the directory " c:/_ate/ "
Thanks a lot
Valery
(3,644 Views)
Valeriv,
These kind of crashes, especially sporadical crashes, can be quite hard to fix. Most likely, the error is occuring in an external DLL( memory issues, wrong pointer when releasing memory, etc). What I suggest is to begin removing parts of your code and test sequence until your application does not crash. Then you will localize the problem. For your case, it may be taking out half of the steps in you test sequence. If the error still occurs, then the problem is in those steps. If not, then the problem is in the other half. Repeat this until you find where the error is occurring. If there are some DLLs called in cycles with delays, then try to reduce delays - this "stress test" may give you exception faster. Also logging of the execution may be helpful. Refer to this thread, for example.
Message Edited by CorbinH on 12-12-2008 11:55 AM
(3,608 Views)
