NI TestStand
Test Stand Running Sequence List
I am running test stand/labview set up on multiple machines.  I have one machine that will not display a sequence list while running (rest of them are fine).  The screen is blank until sometimes near the end of the sequence and even then it is not synchronized with what is happening.  The test sequence is doing what it is supposed to do otherwise
Hope this makes sense to someone, I can add some screen shots if it helps clarify.
Have a nice weekend
(2,645 Views)
Do you mean completely blank?  Or just most of the TestStand screen?  My initial guess is that tracing isn't enabled.  Check at Execute->Tracing Enabled or Configure->Station Options->Execution->Enalbe Tracing
Pulido Technologies LLC
(2,635 Views)
Accepted by topic author acurda123
That did it :).  Thanks for taking the time to help.  I've been using labview for years but am still new to test stand
(2,602 Views)
