NI TestStand
Test Stand 4.0 error code -17001 when executing Message Popup
I am running Test Stand 4.0 and when I execute the Message Popup with a picture Test Stand errors out with error code -17001. The same Test Stand code running on a another PC and does not have any issues executing the same sequence with the same picture. I validated the path is correct for the picture and if I click on the Options Tab and uncheck the Display Image or Web Page box Test Stand executes the Message Popup with no error. Any help would be appreciated.
(2,697 Views)
The following KnowledgeBase article suggests that you may not have the required software or an ActiveX error. If you are using LabWindows CVI in your sequence, this may be the cause.
Why Do I Receive Error -17701 When Running TestStand Sequences?
From http://digital.ni.com/public.nsf/websearch/8ECEC93FD1B7348F86256BB900733494?OpenDocument
Anthony M.
Applications Engineering
(2,657 Views)
