NI TestStand
Terminating Test Stand causes syncronization error
Terminating Test Stand 3.5 before the sequence finishes seems to be causing my two PXI-5102 digitizers syncronization errors the next time I run the sequence.  The master digitizer triggers on an edge like it's supposed to, but I get LabVIEW error -1074126845 from the slave digitizer which makes me think the slave is not triggering.  I have to cycle power to clear this condition.  Is there a way I can prevent this - possibly in the Test Stand Cleanup section?
(3,508 Views)
Hello Joe,
I found this knowledgebase article that might be useful to you. Indeed, it seems that the slave is not triggering. Does it trigger fine when you run it in LabVIEW (outside the TestStand environment)?
Tarek B
(3,484 Views)
