NI TestStand
Terminatin LV code module using Termination Monitor
To terminate the LV code module I'm using three VIs: TestStand - Initialize Termination Monitor (put before while loop), TestStand - Get Termination Monitor Status (put within while loop) and TestStand - Close Termination Monitor (put after while loop).
All these three VIs are within one parent VI on the same 'layer'. The solution works.
However, the solution doesn't work if I put the first out of these tree VIs 'one level higher' i the hiearchy on the same layer as the 'parent' VI from description above.
Are they MUST be on the same layer?
Why?
(3,910 Views)
Nope, they don't need to be on the same layer. The cluster that the Init VI returns is just a handful of ActiveX references, which are valid wherever. It would help if you were more clear as to what "doesn't work" means - do you get any errors, or the VI simply ignores the termination? Make sure everything (especially that cluster) is wired through properly.
(3,908 Views)
Throwing an error 93.
I'll have a go one more time.
(3,851 Views)
Try whittling down your app and post an example that reproduces the problem.
(3,849 Views)
