NI TestStand
Terminate All Threads
Hi All.
I am running a main sequence calling sub sequences to perform tests on a product. While this main sequence is running I need to be monitoring a couple of DIO lines, and should either of these lines change state then all testing should cease. I have tried using a sub sequence call as a new thread to monitor the DIO. The new thread performs as expected but does not terminate execution of the whole sequence as i need i.e. the main thread (testing) continues.
Is it possible to terminate the main thread from a child thread or is there a better method to tackle this problem.
Using TestStand 2010
Thanks in advance
Ian
Message 1 of 9
(6,673 Views)
Try using "Engine.AbortAll"
Message 2 of 9
(6,667 Views)
Accepted by topic author IanR
Use
Engine.TerminateAll
Be aware if you Abort then you don't run any Cleanups. Always use the Terminate methods if you have to shut down this way.
Regards
Ray Farmer
Message 3 of 9
(6,660 Views)
Thanks for the responses guys. Not having used the API before it was a struggle to figure out how to use it. Eventually managed to figure it out and used the TerminateAll function which works fine.
Thanks again.
Message 4 of 9
(6,651 Views)
Hi Ian,
Actually how do you call the API?
I tried to use terminateall from the expression, but it gives me error. "Evaluation error: you are trying to use the TestStand API method 'IEngine.TerminateAll'. You must use parenthesis to call a method."
Message 5 of 9
(6,367 Views)
Toyan,
Try:
RunState.Engine.TerminateAll()
Let us know how it goes!
Message 6 of 9
(6,360 Views)
Since there is only one execution involved you should also just be able to do:
RunState.Execution.Terminate()
-Doug
Message 7 of 9
(6,357 Views)
Toyan,
Simply, change adapter type to ActiveX/Com and add action step type as shown in attached diagram.
Message 8 of 9
(6,353 Views)
Thanks all.
i finally manage to terminate it.
i use the method as shown by Joe and it works perfectly.
i tried to write RunState.Engine.TerminateAll in post expression, but somehow it doesnt work. maybe that time i have conflict with the parameter value.
anyway..thank you all 🙂
Message 9 of 9
(6,340 Views)
