NI TestStand
TS2012 - SequentialModel customization to include sequence version and path in report header
I've been able to add a PreUUT callback to a single sequence to allow me to include the SequenceFile.Version and SequenceFile.Path to the header of my report.
Station ID: TESTENG6-DMA
Serial Number: NONE
Date: Friday, October 17, 2014
Time: 9:35:09 AM
Operator: pbrooks
Execution Time: 14.0482135 seconds
Number of Results: 25
UUT Result: Passed
Part Number: 423-00079
Manufacturer Name: *******
Manufacturer Location: *******
Test Mode: Production
Sequence Version: 0.0.0.130
Sequence Path: C:\Sonus\UX\UX Common.seq
In the callback, I get the sequence file reference using RunState.SequenceFile.AsPropertyObjectFile.
I don't want to add this callback to every test sequence, so I want to modify the SequentialModel PreUUT sequence to add the SequenceFile.Version and SequenceFile.Path to the report header instead.
What technique should I use to get a reference to the running sequence file from the process model PreUUT?
(4,589 Views)
Accepted by topic author PhillipBrooks
Phillip,
You can use RunState.ProcessModelClient to access the client sequence file in the process model.
Hope it helps!
(4,583 Views)
