NI TestStand
Sytem Time
Why isn't my 'x-axis' System Time displayed while using a Waveform Chart when autoscaling is enabled??  I have needed to customize the x-axis Format Time display using Absolute Time for my application.
(3,089 Views)
I think you are on the wrong discussion board.  What software are you using?
If you are using LabVIEW then you need to build the waveform using the Build Waveform function.  Pass your array of Y values to the Y component and then use the Get System Date/Time for the t0 component.
Hope that helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,084 Views)
