NI TestStand
String find failure in TS v3.5
What's wrong in attached string find sequence ?
If the stringToSearchFor is starting from the first character of the string, I cannot get the Teststand v3.5 to find it.
Petri
(3,438 Views)
If the find finds the text at the start, the return index will be 0.
If it doesn't find it the function returns -1.
Are you sure your precondition is correct?
Regards
Ray Farmer
Regards
Ray Farmer
(3,432 Views)
Thanks Ray for quick answer!
Yes, elementary fail in if condition.
Petri
(3,430 Views)
Hello!
Please, just change your 'If' condition since to 'Greater Than Equal' and it will work fine.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,391 Views)
