NI TestStand
String Value Test using DLL which has an external function error
I created a DLL CallFromTestStand2_dbg.dll, in this DLL there a function call another function that does not include in the same file but in 1 project (I did create 2 separate object files & .h file)
- When I use anther CVI project UseCallIndirectDLL to use this DLL ... it works fine
- However, when I try to use TestStand with Sequence String Value Test (TestCallCVI_DLL.seq), it failed and showed error -17709 error loading String Value Test  ... even I try to use Source Code Edit to use TestStand option Tscvivrun)
Note: If I do not use other function in another file and insert that function in the same file then it work OK
The reason I ask for is that I need to create a DLL that can use external functions not in the same file ... can we do that by any way?
Thanks for any help
I attach a zip files related to my question
(3,166 Views)
Oopps, I forgot to attach my zip file
(3,165 Views)
Are you linking to these DLLs inside the actual code? Or are you using CVI to link the two DLLs together?
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(3,142 Views)
