NI TestStand
Stopping Sequence From Failing
I was curious as to whether not there is a way to pull the latest results of a reiterated step or sequence. For an example if I have a step or sequence that fails and I then use a pop up message to return to that step and I pass it, I want the step to record a pass. However, in Teststand the Sequence or Step will fail even if it passes on the reiteration. Is there a way to prevent this or just pull the most recent status of the step or sequence?
Message 1 of 8
(4,570 Views)
Hi
Maybe this old thread will be interresting.
http://forums.ni.com/t5/NI-TestStand/Repeating-a-Failed-Sequence-once-more/td-p/1042268
Here you have to posibility to repeat a fail sequence one more AND before repeating you will get a report of excatly that sequence.
In the example there a some expressions for "resetting".
OK I am honest: repeating is a really strange stuff.
But setting failed to passed via Messagebox is absolutely strange.
I am curious about this behaviour.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 8
(4,546 Views)
Hi j_dodek,
I have reviewed the post that you have sent me and I was curious if there was just a way to clear a failed step. The idea here is that the user has failed a step due to a mis-measurement and to allow them to re-enter a measurement without the failure reporting. They would fail the step, then follows a logic if-statement, which returns them back to instructional dialogs and then back to the step to repeat. This way the user's screen won't show a Fail for the Sequence and would show a Pass for the Sequence and Step.
Message 3 of 8
(4,541 Views)
Hi AllanIL
this was done in example. It is repeating a failed step
with following conditions: Step must be a SequenceCall and this step must be inside the MainSequence.
If you get rid of the conditions it should "work" for all kind of steps.
Juergen
--Signature--
Message 4 of 8
(4,535 Views)
Hi j_dodek,
I had errors running the sequences, could you possbily send me your sequence? I also cannot have the sequence repeat any given failed step, but rather specific ones I desinate as I have a series of subsequences called in the main sequence.
Message 5 of 8
(4,527 Views)
Hi
Seems Version III was not working correctly.
I have updated it. now on my maschine (TS2016) it is running.
Just copy SequenceFilePostStepFailure to your SequnceFile and all SequenceCall from MainSequence were repeatable.
Regards
Juergen
--Signature--
Message 6 of 8
(4,522 Views)
Hi j_dodek,
I am working in TS 2014, both sequences were saved in TS 2016 and I cannot open them.
Message 7 of 8
(4,520 Views)
Ups,
now it should work.
Small modification: After 2 failed the third one will pass.
Regards
Juergen
--Signature--
Message 8 of 8
(4,490 Views)
