NI TestStand
Specify stylesheet relative to the reports in the same server
I'm using TestStand 2017 32-bit.
I need to generate Reports in ATML 6.01 format. I would prefer that the generated xml refer to the stylesheet in a relative way. I also prefer to set this in the client sequence.
I've tried unsuccessfully different settings by changing the following parameters (overriding ReportOptions callback):
StoreStylesheetAbsolutePath
RelStylesheetPath
StylesheetPath
Let's say the reports are stored here:
\\server\Reports
and the StyleSheet is here:
\\server\StyleSheets\tr6_horizontal.xsl
If I save a report with
Parameters.ReportOptions.StoreStylesheetAbsolutePath = True
, then the stylesheet address is not set correctly in the xml, because some default Directory is used instead, independently of what I set on StylesheetPath. By changing manually in the xls:
href = ..\StyleSheets\tr6_horizontal.xsl, then I can open the report correctly with Internet Explorer.
But if I use:
Parameters.ReportOptions.StoreStylesheetAbsolutePath = False,
Parameters.ReportOptions.RelStylesheetPath = "..\\StyleSheets\\tr6_horizontal.xsl"
then the report is saved correctly (I can open it with Internet Explorer, for example), but TestStand fails showing the report because the stylesheet reference it tries to use is "C:\Users\<Windows user>\AppData\Local\Temp\TestStand\..\StyleSheets\tr6_horizontal.xsl"
Thank in advance.
Message 1 of 1
(1,886 Views)
