NI TestStand
Specify Report File Path by Expression in TestStand 3.5
Dear Friends,
I would be most grateful if you can tell me how to "Specify Report File Path by Expression" for TestStand 3.5.
When we use TestStand 2014, there is no problem to Specify Report File Path by Expression. However, we cannot do the same in TestStand 3.5.
Any instructions and assistances are most appreciated.
James
(2,843 Views)
Hi James,
I found instructions on how to use this feature on a KB. Here's what you have to do:
  1. Navigate to Configure>>Result Processing>>Report Options>>Report File Pathname
  2. Select Generate Report File Path
  3. In the File/Directory Options drop-down menu, select Specify Report File Path by Expression
Good luck 🙂
(2,807 Views)
Good Morning Jesicadiaz,
Thank you very much for your attention and help.
This option is OK for TestStand 2014, but not available for TestStand 3.5, as shown in the attached image.
James
(2,789 Views)
This feature is only available in TestStand 4.2 and later:
https://zone.ni.com/reference/en-XX/help/370052W-01/tshelp/infotopics/42whatsnew/#expreports
https://www.linkedin.com/in/trentweaver
(2,785 Views)
Accepted by topic author James_Creation
Thank you very much for your information, Wire Weaver
(2,780 Views)
