NI TestStand
Simple Operator Interface GUI
When I run the Simple Operator Interface (SOI)  the "STOP, REFRESH,HOME, etc" buttons in the lower display vi appear to be up too high in the display window.  If you look when I run it you can just see the boxes in the display window.  If I hover my mouse button over them they appear in the window.  Anyone know why??  I tried to resize the box but it still doesn't do any good.  They "disappear" at runtime.  tried to do a screen capture but windows won't let me when I run the SOI.
Clint
(3,778 Views)
Hi Clint,
This is definately strange.  Do you see similar behavior in any of the other simple OIs, or in the LabVIEW full-featured OI?  Also, if you create a new VI and place the TestStand UI ReportView Control, then run, do you see similar behavior?  Your ReportView control may be corrupted, in which case a repair install of TestStand would fix the problem; but please let me know the results of the above tests!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,728 Views)
I tried to go back to the original Simple OI ( to see if I got the same behavior) but silly me for got to copy over the llb into the user directory 1st.  Now the original simple OI is modified.  I looked on the NI website to see if I could find the original llb but couldn't.  I was going to call NI or post here 1st.
 The Sw is on a Test Staion in the Lab.  I have to get back to my desk to see if the original Simple OI is thereso I could at least get back to square 1.
To answer your question, No.  I haven't tried it w anything else.  I guess I could attach the OI I'm having trouble w and see if you see anything.  i did mod it behave as I required.
Clint
(3,718 Views)
Hi Clint,
Probably the easiest way to restore the OI is to move all of your cusomized files out of theTestStand directory, then repair the installation.  This can be done through add/remove programs in windows.  Please feel free to attach your OI, and I'll let you know if I get the same behavior.
Al B.
CTA/CLD
(3,698 Views)
