NI TestStand
Sharing variable on parallel test
on parallel test for create a dynamic variable visible to all thread (on TestStand 2014), can I use a StationGlobal variable or exist another way?
Thank you
(2,878 Views)
Accepted by topic author TomDev
You can use StationalGlobal; or you also can use FileGlobals (if you have option Edit -> Sequence File Properties -> Sequence File Globals -> All Executions Share the Same File Globals).
Sincerely, kosist90
(2,853 Views)
