NI TestStand
Several outputs from single step
When the attached SEQ file executes the output D will appear in the test result. How do I get the rest of the outputs (Boolean and outputs A to C) in the same report.
(2,909 Views)
I have attached a modified sequence file called Test1.
This has and extra step which is a Multiple Numeric Limit Test step type. Each for the A, B, C, D results have been assigned an element of an array which holds the results.
I haven't modified the limits but each result can have seperate limits which you set via the Edit Limit Dialogbox.
If you change your boolean so that it returns 0 or 1 then Element 0 of the array can be used to hold this result.
Hope this answers your query
Regards
Ray Farmer
Regards
Ray Farmer
(2,909 Views)
