NI TestStand
Setting result.reporttext external to code for multiple numeric test step
I have been setting the report text for any given step inside my labview code and passing it out to teststand.  To do that, with a multiple numeric, I would have to pass in the limits and do the evaluation for each measurement, which teststand already does.  Is there a more elegant way to do this in a post step?
(1,483 Views)
What are you trying to put in the report text?
You could use a post expression.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,435 Views)
Thanks I can try that, but it will be a bit of code in a post expression as I have to cycle through all of the measurements in the array and the associated limits, then set the report text with a custom test name which isn't the step name.  But I cannot loop in a post expression
(1,398 Views)
Maybe try to use PostResultListEntry callback and generate your ReportText there?
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,386 Views)
