NI TestStand
SequenceFilePostStepFailure call back stuck
I have a problem, I am trying to perform retries of some steps inside a For loop for many files. My solution is that I have set up a SequenceFilePostStepFailure. The For Loop has 5 to 7 steps to perform and a step which is the evaluation point for the test.  But once this step fails I have to redo all the steps in the For Loop at least once otherwise end the test. My solution is easy on the step that I should start the retry I have set a local variable 'RetryStepIndex' and I set the variable to RunState.StepIndex and in the SequenceFilePostStepFailure I have set the next step RunState.Caller.RunState.NextStepIndex = RunState.Caller.Locals.RetryStepIndex. This works fine when debugging and TestStand. But I when I deploy it with a user interface the test does not work fine its always stuck after performing the call back.
By the way I have another call back that deletes the retries test results from the report.
I have attached the simple sequence I am using for testing and debugging
(2,817 Views)
Hi Marius090,
Can you elaborate on what happens when it is deployed? Does the test just freeze or does it end?
Justin
(2,758 Views)
I found a solution, unfortunately some had played with the configuration of the pc on the Test statation, They had set "stop when sequence fails" on and that caused the sequence to stop.
(2,748 Views)
