NI TestStand
Sequence file version conflicts - TS_EngineNewExecution
Hej NI Community,
I have programmed an stand alone application, which can execute sequence files. The CVI application is programmed with CVI 7.0 and Teststand API 4.0. You can select a sequence file and run the application without the SequenceFileEditor...
My sequence file is programmed under Teststand 4.1 and uses sequence file library functions, which are developed with Teststand 4.0 (stored in different sequence files).
I can run the sequence file under Teststand 4.1 (SequenceFileEditor) without any error messages. My own application cannot run the sequence file. The function TS_EngineNewExecution comes back with a error message:
_______________________________________________________________
Error code: -2147352567
CA automation error string: Ausnahmefehler aufgetreten.
Teststand API error information:
wCode: 0
sCode: -17329
source: TSAPI
description: Error loading step 'In-Circuit-Test' of sequence 'MainSequence' in file 'bscan_demo.seq'.
Error loading step 'Insert name of step into operator interface' of sequence 'Load and run ICT program' in file 'Test_Library.seq'.
Type 'NumericLimitTest' is invalid because it conflicts with the existing type of that name. To avoid this error message, you should open the file with the type conflict in the Sequence Editor and resave it.
The sequence file 'C:\Program Files\Sequences\Utility_Library.seq' could not be loaded.
helpFile:
helpContext: 0
errorParamPos: -1
I can resave the sequence to avoid this message. My own application can execute the sequence file after resaving. The library is saved now in Teststand 4.1 format. But this is not my interest.
Can anyone tell me, why the sequence editor (4.1) don't show me any error? How must I program my own application to avoid this error message?
Thanks a lot.
Message 1 of 10
(6,122 Views)
Can you load the sequence file in your application without an error? Then you could try loading it in your application and saving it programatically before running it.
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
Message 2 of 10
(6,098 Views)
Is your OI and SeqEditor on the same system or is one only on a target system.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 10
(6,094 Views)
The SeqEditor and my OI are installed on the same system. TSAPI is not included in my app. So my OI uses the actual activated Teststand Engine.
Should I post my code?
Message 4 of 10
(6,066 Views)
If you can.
Regards
Ray Farmer
Regards
Ray Farmer
Message 5 of 10
(6,064 Views)
Hej,
I'm posting my tracefile. I think its easier to unterstand. Here are tracing with the error:
0.000s      Program started
0.000s      Tracing started
0.002s      Function LoadPanel finished with no errors
0.000s      Initialize Teststand Engine
0.892s      Function -->   TS_NewEngine finished with no errors
0.000s      Function -->   TS_EngineRegisterUIMessageCallback finished with no errors
0.001s      Function -->   TS_EngineSetProperty finished with no errors
0.000s      Function InitEngine finished with no errors
0.000s      Start login process
0.000s      Function -->   TS_EngineNewPropertyObject finished with no errors
0.000s      Function -->   TS_PropertySetValBoolean finished with no errors
0.030s      Function -->   TS_EngineCallFrontEndCallback finished with no errors
0.000s      Function -->   TS_ExecutionGetProperty finished with no errors
0.000s      Function CallLoginLogoutCallback finished with no errors
0.000s      Show panel behind logon panel
0.017s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.000s      Function -->   TS_UIMessageGetProperty finished with no errors
0.003s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.011s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.224s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.247s      Waiting for Login
0.500s      Waiting for Login
0.086s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.000s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
0.005s      Logon process done
0.000s      Check user
0.000s      Function -->   TS_EngineGetCurrentUser finished with no errors
0.000s      User can run any sequence
0.000s      Function CheckUserPrivilege finished with no errors
0.000s      Open sequence
0.000s      Show file select popup window
1.297s      Function -->   TS_EngineGetSeqFile finished with no errors
0.000s      Sequence file path is:
0.000s      c:\Program Files\Spectral Electronic\SW-ITS\Projects\BScan_Demo\bscan_demo.seq
0.000s      Function OpenSequence finished with no errors
0.000s      Check sequence
0.000s      Function -->   TS_SeqFileSequenceNameExists finished with no errors
0.000s      All sequences found, iStartSequence automatically true
0.000s      Function CheckSequence finished with no errors
0.000s      Start execution of loaded sequecence
0.248s      Function -->   TS_SeqFileGetModelSeqFile finished with no errors
3.123s      An error has occurred in function: -->   TS_EngineNewExecution useProcessModel
wCode: 0
sCode: -17329
source: TSAPI
The sequence file 'C:\Program Files\Spectral Electronic\SW-ITS\Sequences\Utility_Library.seq' could not be loaded.
helpFile:
helpContext: 0
errorParamPos: -1
0.015s      Function -->   CA_CreateObjHandleFromIDispatch finished with no errors
4.303s      An error has occurred in function: ExecuteSequence -> Test UUTs
Error code: -1
Error message: No error message
0.628s      Start free all resources
1.060s      Free all resources done
0.000s      Tracing stopped
0.000s      Programm ended
Message 6 of 10
(6,051 Views)
_____________________________________________________________________________________
This is the tracing after resaving. See attachment:
If you have questions about the functions calls, please ask me.
Thank you very much.
Message 7 of 10
(6,050 Views)
Accepted by topic author renr
renr,
Is you standalone application using the Application Manager UI control? If not, your application should be calling TS_EngineLoadTypePaletteFilesEx() after creating the engine. The Application Manager does this for you, but if you are not using the Application Manager control then you need to do it explicitly. If the type palette files are not loaded then you will get whatever version of the types were last saved for the sequence file rather than the version that ships with the version of TestStand you are using. I suspect that this is the problem you are seeing based on the error message you are getting.
Hope this helps,
-Doug
Message 8 of 10
(6,043 Views)
It works. Thank you!
Message 9 of 10
(6,026 Views)
For anyone else in this situation, or experiencing similar trouble, if you are writing a User Interface directly using the TestStand API, then you will want to reference this help topic:
Writing an Application with the TestStand Engine API
If you are using the TestStand UI controls, which are usually an easier choice, you can reference this help topic:
Writing an Application with the TestStand User Interface Controls
Josh W.
Certified TestStand Architect
Formerly blue
Message 10 of 10
(6,011 Views)
