NI TestStand
Save Properties to file
I'm using TS2017 together with a C#-GUI.
In TS I use the PropertyLoader-Step to load some Default-values from a txt-file.
I created this txt-file once with the Import/Export Tool.
With the C#-GUI the user is able to change these values.
Now I want to save the changed values to this txt-file when testing is finished.
I found an example-sequence where the Import/Export Tool is executed.
But this requieres an user interaction, so you have to click some Buttons.
Is there a way to do this completely Software controlled?
Thanks in advance for the answers.
Regards
skahlau
Message 1 of 1
(2,119 Views)
