NI TestStand
SQL "View" with TS?
is it possible to handel a SQL "View" with TestStand or the Database Viewer?
I can see my tables but not the view.
greetings
schwede
(3,886 Views)
In the Database Viewer you need to execute a query to get your VIEW results. For TestStand itself you can modify the database schemes and statements in Configure > Database options or use custom SQL query steps.
Creating a TestStand Database Schema from Scratch
Best Regards,
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,857 Views)
that's not what i mean. I have createtd an udl-file to connect to the datatbase. If i call this from excel i see all my tables and the "view".
When i call this from the database viewer i can see only the tables and not the "view".
greetings
Schwede
(3,832 Views)
Did you try changing the Viewer options?
Andreas Stark
(3,824 Views)
Thankyou,
this is the first thing, the second is that i can`t write to the database.
If i use a table everything is ok. When i took the view i get an error-message:
-2146825037 The recordset don`t support updating. This can be a problem of the constriction of provider or lock type....
Can you help me with this, too?
greetings
schwede
(3,821 Views)
Does that help?
http://digital.ni.com/public.nsf/allkb/A324D2172DD09C08862570F8004FA3C3?OpenDocument
If not please upload your database scheme so I can try to reproduce it here.
Andreas Stark
(3,809 Views)
That doesn`t help.
I have attached the file.
schwede
(3,792 Views)
