NI TestStand
SQL data base
Hello All,
I am new to the SQL , I configured teststand to MySQL connector version 3.5x as the instrunction I updated in configuration settings.and set the My sql results data base .I am getting the above error .
Help in solving the about error .
Padugur
(4,657 Views)
Accepted by topic author Padugur
It's stating that the datalink is invalid.
You should open up the database, make sure the Database Management System is set to MySQL and click "Build". A connection screen will pop up and ask you to determine the server name and the login. After that, you should have enough info entered to click "Test Connection". If everything works, it will say "Test Connection Succeeded" Select the database and it will autopopulate your connection string.
It performs the same check when you Test Connection as when they log data. So if successful in one location will be successful on both.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
(4,650 Views)
