NI TestStand
Runtime Error R6025 and DAQ-Driver
Operating System Windows2000
Teststand  Version 3.0
DAQ-Driver  6.9.3f5
Serial Driver  1.7
LabvIEW RTE build with LabVIEW 6.1
hello,
we have build a testsytem based on LabVIEW and Teststand.
We use the NI-PCI boards 6713, RS232/16 and MIO-164E. We dont use any operator interface, only the
original Teststand sequence-Editor and the Single-Pass Prozess-model.
It works very fine for  e.g. a whole week running and then
,suddenly, the ERROR Window pops up :
"Window-Head: Microsoft Visual c++ Runtime Library
RUNTIME ERROR
Programm ...\National Instruments\Teststand3.0\Bin\SeqEdit.exe
R6025
- pure virtual function call"
After pressing the OK-Button, the Computer will boot and generate a memory-dump.
We have analyzed the dump-file with the Microsoft WINdbg Tool.
The Bugcheck Analysis reported an error with the Nidaq32k-Driver !!
What should/can we do ?
See below the analysis report:
Debugging Details:
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for Nidaq32k.SYS -
OVERLAPPED_MODULE:  kmixer
FAULTING_IP:
Nidaq32k!mdsSimpleDIGPortPrimitive::_accessCheck+600
bc4370a0 c745fcffffffff   mov     dword ptr [ebp-0x4],0xffffffff
DEFAULT_BUCKET_ID:  INTEL_CPU_MICROCODE_ZERO
BUGCHECK_STR:  0xCB
LAST_CONTROL_TRANSFER:  from 804bce30 to 80440665
STACK_TEXT:
bc175c54 804bce30 80064bd4 00000000 804bd199 nt!MmCleanProcessAddressSpace+0x421
bc175d04 804bd1b3 00000000 84973a28 80431261 nt!PspExitThread+0x4e1
bc175d10 80431261 84973a28 bc175d48 bc175d3c nt!PsExitSpecialApc+0x1a
bc175d4c 80465bfa 00000001 00000000 bc175d64 nt!KiDeliverApc+0x158
bc175d4c 77e017da 00000001 00000000 bc175d64 nt!KiServiceExit+0x58
WARNING: Frame IP not in any known module. Following frames may be wrong.
0012f7a4 00000000 00000000 00000000 00000000 0x77e017da
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
FOLLOWUP_NAME:  MachineOwner
SYMBOL_NAME:  Nidaq32k!mdsSimpleDIGPortPrimitive::_accessCheck+600
MODULE_NAME:  Nidaq32k
IMAGE_NAME:  Nidaq32k.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  3f39592e
FAILURE_BUCKET_ID:  0xCB_Nidaq32k!mdsSimpleDIGPortPrimitive::_accessCheck+600
Followup: MachineOwner
(4,248 Views)
hello frank,
do you have older versions of the LV RTE installed on your system?
take a look at this thread. maybe the removal of an older LV RTE solves the problem.
regards,
robert h
national instruments
(4,216 Views)
Hello Robert,
the windows 2000 system control shows only two LV RTE`s:
- Version 7.0 ( i think needed, an installed during Testand installation process...)
- Version 6.1 , installed for our application by me
I before already deleted old versions (I dont know from where they are ... ?) , because I knew the older thread with the R6025-Error ...
But:  the MAX (Version 3.0) shows additionally the LV RTE Version 6.0 !
Could this be the problem ?
thanks for help and best regards
(4,209 Views)
hello,
could you try to remove this old version with the msiBlast tool, which is also linked in this thread?
regards,
robert h
(4,204 Views)
hello,
unfortunately the msiBlast tool dont indicate the LV RTE 6.0 !, too.
See attachment  .pdf file for all installed applications
So it seems to be a other problem of the MAX Version 3.0, showing a LV RTE, which does not exists.
(The expected folder ...\shared\LabVIEW Run-time\6.0 is not present, too.)
Nevertheless i dont have any idea to solve the problem with the R6025 Error ?
Note: In case of manually killing the LV TS RTE within the windows system control (testsequence is running) , a blue screen with error indication for nidaq32k.sys arises !?
regards
(4,189 Views)
