03-30-2021 04:02 AM
Hello all,
I have developed a sequence in which I record several results in the report.
But sometimes I get this error at the end of the test, when I run the result processor
I can't figure out what the bug is because the error appears unpredictably and sometimes it doesn't even appear
I attach a screenshot to this message
any clarification is welcome.
Thanks.
Chakib,
03-30-2021 04:31 AM - edited 03-30-2021 04:39 AM
For more details,
I record my results using additionnal result.
Below, the step wich causes the error
the step above calls this :
error :
I tried to find "TS.StepType" Manually you can see the screenshoot below :
I don't understand why the software tells that he can't access to StepType above but I can find it manually !
