NI TestStand
Run tests parallel for one uut
Hi,I am new to TestStand ,I want to run multiple tests at the same time in parallel;I put 2 tests in the main sequence that measures the frequency and amplitude of a signa l(LabVIEW), in the sub-sequence I have 2 tests that measures random numbers.What I am doing is i am making a sequence call and enabling "Use new thread". The problem is, I can't see the measurements and pass fail status of the sub-sequence,It just shows done.I can see the main sequence measurements.
Help!
(2,336 Views)
Accepted by topic author skywalker1357
Hello Skywalker1357,
By default, the sequence you are running in a new thread will be waited by the calling sequence. If you want to get the result list in the calling sequence (and get the corresponding data in the report), use a Wait step on Thread, and point to the New Thread sequence call (Wait Step Configuration Dialog).
See the Wait Step help for further information.
Hope this helps;
(2,286 Views)
