NI TestStand
Run-Time Error Dialog Box Retry Button Disabled
After upgrading our PCs to Windows 7 and to TestStand 2015 the Retry button on the Run-Time Dialog Box is now disabled.  It's a permissions thing because this only happens when logged on at the Operator level.  Is there a way to re-enable without bumping my tester to an admin account (that would be bad...)  The previous station/teststand configuration the button was enabled.
(1,226 Views)
You know how when you FINALLY breakdown and ask for help you find the answer?
Setting User Manager  - Groups - Operator - Privileges - Debug -  ControlExecFlow to True fixes the problem. (user is a member of the Operator Group)
(1,190 Views)
