NI TestStand
Result filtering works for ASCII but not for database result processing
The following result filtering expression works for the ASCII text file result processing but not for the database adapter. Why is that?
Result.Status != "Done" && Result.Status != "Skipped"
An error occurred calling 'LogMultipleResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred evaluating the database logging result filter expression.
Unknown variable or property name 'Result'.
Error accessing item 'Result'.
Source: TSDBLog
(2,290 Views)
I found the answer poking around. I want:
Logging.StepResult.Status != "Done" && Logging.StepResult.Status != "Skipped"
for the database result processing filter expression.
(2,280 Views)
