NI TestStand
Releasing object referrences from station variables
I am creating object referrences for both Active X and .NET components.  These objects must be used throughout multiple sequences within the mainsequence.  I am looking at relaesing the objects at the end of the mainsequence, but so far, all I can currently do is use an expression statement and state
objectreferrence = ""
Is there a better way to do this.  I have tried setting equal to null, but that is coming back as invalid.
(3,020 Views)
Set to object to Nothing
eg
Locals.SeqObj = Nothing
Regards
Ray Farmer
(3,019 Views)
In addition to Rays correct answer, you should make sure that the objects do not provide a dedicated shutdown routine.
Simply setting the reference to Nothing will free tha handle, but this could lead to object leaks.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,014 Views)
The handle is one concern to make sure that the object can be created and used again.  Also, the leaks are my biggest concern.
(3,011 Views)
