NI TestStand
Regarding NI Voltage module configuration
I wanna conduct a vibro-acoustic test for that  I am going to use the following devices:
1. Accelerometer (General purpose, sensitivity of 100 mV/g)
2. Impact hammer (10 mV/lbf)
3. Microphone (50 mV/Pa)
4. Acoustic emission sensor (100-400 kHz) + Preamplifier
Q1. Is it possible to have a common NI module that must be compatible with above all devices?
Q2. will NI-9223 be compatible with above all devices?
Q3. Should I buy NI-9234 for first three and NI-9223/NI-9221 for fourth one?
Q4. Actually, NI-9221 is a screw/spring type input so how can I connect with BNC, Because my acoustic sensor is BNC type.
Thank you very much.
(1,443 Views)
I think this question shall be asked on HW Board since it's not related to the NI TestStand test executive.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,430 Views)
  • Can you measure the thickness of paper using a common scale? yeah, but will it give you correct results -no, similarly not all requirements can be solved using a single solution
  • In electrical terms, yeah, they are compatible because all those are voltage-based sensors, but as explained earlier there are many things to consider.
  • Typical accelerometers and microphones use IEPE and TEDS which is not supported by non-DSA instruments like 9223
  • Yeah, I would recommend a DSA instrument for accelerometer and microphones as they have a great resolution (24-bit) and support IEPE/TEDS
  • Unfortunately, there are no sound & vibration input modules that can cover that wide bandwidth for 4th one and you have to go with the generic Analog Input cards
  • There are BNC to wire adapters that you can buy
Santhosh
Soliton Technologies
(1,420 Views)
