NI TestStand
Referencing Label-Step with Goto-Step
Hello, everyone
I have a problem with Goto-Steps in TestStand. In my application I have to repeat test steps within a sequence. In order to keep a visual overview, I grouped steps within the sequence and always put a label step in front of them at the beginning.
Now I wanted to reference label steps with the goto steps, but this sometimes led to problems. I was able to select these, but after changing tabs, the goto-step referenced randomly somewhere.
Is referencing goto to label generally good practice, or are there any known issues?
Many thanks for your help
(2,174 Views)
I made it this in the past without problems.
Can you replicate this behavior with a new sequence file and attach it?
What it your TS version?
(2,150 Views)
Hello carloandreslpz
Thank you for your feedback. Is strange, I could not reproduce the problem with a new sequence file. Ok, but it is helpful for me to know that it is generally not a problem to refer to labels.
Thanks and regards
I work with TestStand 2019
(2,118 Views)
