NI TestStand
Recursive sequence call
I want to call the sequence which I am running in the same sequence recursively, along with sending some variable values to the sequence which I want to use after the sequence call. I found a way of doing it by calling the same sequence and by using "Parameters" I can pass the new values to the same sequence. But I want to know is there any other way of performing this recursive action for a sequence?
(3,931 Views)
Try this -
For the variables which you want to pass to sub-sequence enable the flag 'Propogate to Subsequence'
(3,916 Views)
Those variables are going to be created dynamically.
(3,891 Views)
