NI TestStand
Reading fileGlobals variable error at run time in TestStand using C#.NET
Hi, All
Please correct the code. The problem is in reading FileGloabals values at run Tiime
exeObj1 = ObjEngine.NewExecution(stepSeqFile,objStepSeq.Name,stepSeqFile,
false,ExecutionTypeMask.ExecTypeMask_Normal,System.Reflection.Missing.Value,
System.Reflection.
Missing.Value,System.Reflection.Missing.Value);
TSth1 = exeObj1.GetThread(0);
nCallStkSize1 = TSth1.CallStackSize;
for (int nContextIndx = 0; nContextIndx < nCallStkSize1; nContextIndx++)
objContext1 = TSth1.GetSequenceContext(nContextIndx,
out nFrameID);
ptrSequence1 = objContext1.Sequence;
bool value = false;
int nStepCount = ptrSequence1.GetNumSteps(StepGroups.StepGroup_Main);
objPropertyObj = objContext1.FileGlobals;
while (value == false)
//TSth1.WaitForEnd(-1, true, null, null);
//objPropertyObj = TSth1.AsPropertyObject();
exeObj1.WaitForEndEx(-1,
true, null, objContext1);
strOutPutValue = objPropertyObj.GetValString(
"FileGlobals.Output", 0); // Getting error. Errror to access item "FileGlobals.Output"
(3,288 Views)
rkk,
Haven't you already got a thread running on this?
http://forums.ni.com/ni/board/message?board.id=330&thread.id=18398
Ray
Regards
Ray Farmer
(3,285 Views)
rkk,
You are using a reference to FileGlobals "objPropertyObj" therefore the lookup string is not "FileGlobals.Outputs" but "Outputs".
Regards
Ray
Regards
Ray Farmer
(3,284 Views)
