NI TestStand
QControl | License File Deployment Location in TestStand
I’m developing a custom step in TestStand using LabVIEW, and the LabVIEW code for this step depends on VIs from the QControl library. The QControl library is licensed under the Revised BSD license. I plan to deploy the LabVIEW code as a Packed Project Library (PPL) in the TestStand Public Documents folder.
Given that the QControl library is a dependency, could someone tell me where in the TestStand directory structure I should place the QControl license file to ensure proper compliance and visibility?
Thanks!
(450 Views)
The license file is located next to the majority of the QControl Toolkit code.
C:\Program Files[ (x86]\National Instruments\[LabVIEW 20xx]\vi.lib\QSI\QControls\LICENSE
[ x86] for 32-bit, leave off for 64-bit
[LabVIEW 20xx] is the LabVIEW version folder it is installed to (e.g. LabVIEW 2025, LabVIEW 2020, etc.)
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(396 Views)
