NI TestStand
Python script to open Teststand seq files
I am using python to open very simple teststand seq file as shown below:
import win32com.client
try:
tsEngine = win32com.client.Dispatch('TestStand.Engine.1')
sequencePath = 'Sequence File 1.seq'
seqFile = tsEngine.GetSequenceFileEx(sequencePath)
execution = tsEngine.NewExecution(seqFile, "MainSequence", None, False, 0)
execution.WaitForEndEx(60000)
print(execution.ResultStatus)
released = tsEngine.ReleaseSequenceFileEx(seqFile, 0x4)
except Exception as ex:
print(ex)
Using the above code, I am able to open the seq file, and get the ResultStatus at the end of the execution.
After that, I called ReleaseSequenceFileEx() to release the reference to the seq file.
However, I encountered the following Teststand's warning very frequently.
Please help.
The Engine.ReleaseSequenceFile(Ex) method was not called for the following files:
    C:\Program Files\National Instruments\TestStand 2016\Components\Callbacks\Station\StationCallbacks.Seq
    C:\Users\Public\Documents\National Instruments\TestStand 2016 (64-bit)\Components\Callbacks\Station\StationCallbacks.Seq
References to PropertyObjects were not released properly.
    Total number of objects: 228
    Number of top-level objects: 19
    Note: Some top-level objects may be included if they are referenced by
    an incorrectly released top-level object. For example, an unreleased
    SequenceContext object references a SequenceFile object.
    The following top-level objects were not released:
        Executions [1 object(s) not released]
        Files [2 object(s) not released]
            SequenceFile #1:
                Path: C:\Program Files\National Instruments\TestStand 2016\Components\Callbacks\Station\StationCallbacks.Seq
            SequenceFile #2:
                Path: C:\Users\Public\Documents\National Instruments\TestStand 2016 (64-bit)\Components\Callbacks\Station\StationCallbacks.Seq
        Type Definitions [3 object(s) not released]
            Type Definition #1:
            Type Definition #2:
            Type Definition #3:
        PropertyObjects [8 object(s) not released]
            PropertyObject #1:
                Type: Obj
            PropertyObject #2:
                Type: Number
                Value: 0
            PropertyObject #3:
                Type: Number
                Value: 0
            PropertyObject #4:
                Type: Number
                Value: 0
            PropertyObject #5:
                Type: Number
                Value: 0
            PropertyObject #6:
                Type: Array of Containers
            PropertyObject #7:
            PropertyObject #8:
        And the following uncategorized objects:
            UIMessage (TEMessage)
            Report
            TypeUsageList (Obj)
            TypeUsageList (Obj)
            EditArgs
(4,230 Views)
I've been doing some work with the Using Python to Run TestStand Sequence File example code and found that to make it close cleanly I need to both handle UIMessages so that there are none outstanding when the code finishes executing and also to use del in Python to remove the seqFile and execution references after releasing the sequence file.
(3,870 Views)
