NI TestStand
Python Step Type - Wait Options
I am using TestStand to invoke a Python script. I would like the sequence to continue to the next step and not wait for the python to exit.
Is this doable? I do not see any wait options like the Call Executable step.
I am using TestStand 2019.
Alex
(3,024 Views)
Hello Alex,
I don't use TestStand 2019 yet. But you should be able to get "assynchronous" processing using a subsequence, calling it in a New Thread. But the feasibility will depend on your script's inputs/outputs. See Edit Sequence Call dialog Box, under Multithreading and Remote Execution » Run Sequence in a New Thread
With a "New Thread" sequence call, you can use a Wait step to collect the Results (result list of the new thread sequence will be append under the Wait step entry).
Hope this helps,
(2,963 Views)
