NI TestStand
Property Loader SQL
Paul -
My suggested debug is:
1) Test with a smaller database table as Norbert suggested to see how that affects the timing.
2) Remove half of the steps from the sequence that you are importing into to see how the timing changes, linearly or not.
3) Change the cusor type and location independently to static and client side respectively.
If you are opening and closing the connection, there should be no need to use a dynamic cursor. Static should be fine.
Client side is typically better performance than server-side unless network traffic is very slow.
Let us know the timing differences with the different changes in options.
Scott Richardson
https://testeract.com
Message 11 of 14
(1,242 Views)
Hi Norbert,
I changed the Configuration of the SQL Statement Step:
Card Advanced, Cursor Location
I changed from Default (which obviousliy means Server) to Client. As a result the Property-Loaders execution changed:
CursorType-Server:
Open SQL Statement   0.046922 sec
Property Loader          16.9857047 sec
CursorType-Client:
Open SQL Statement   0.0331606 sec
Property Loader           0.1644317 sec
Of course I'm happy, that it works now fine, but I still can't understand why the Open SQL-Statement has an appropriate ExecTime
in both cases and the Property Loader needs seconds when the cursor Type is set to Server?
Paul
Message 12 of 14
(1,230 Views)
Hi Norbert, Hi Scott,
Thank you both for your help. The loading of the Limits works pretty fast, since I changed the Cursor Location to Client.
Paul
Message 13 of 14
(1,214 Views)
I would assume that the server you are using is heavily utilized or is limited on resources so maintaining the cursor in the server will be slower than just pushing the appropriate data to the client and the client will then process it.
Scott Richardson
Message 14 of 14
(1,188 Views)
